Can I use the same network name and password for additional eero networks?
If you have multiple eero networks on your account that you use across homes or other locations, you may find it beneficial to use the same network name (SSID) and password as your other network. When you use the same credentials, you'll be able to easily join your other network when moving between locations.
While you can have more than one network with the same name on one account, eero networks do not share information such as device nicknames, network settings, Family Profiles, or any eero Secure settings. You will need to set these for as desired for each network.
