How do I sign up for eero Plus?
Signing up for eero Plus is simple! To get started, first make sure:
  1. You have an eero WiFi system (1st or 2nd generation)
  2. You have the eero app installed on your smartphone (iOS or Android)
  3. Your eero WiFi system isn't in bridge mode
To sign up for eero Plus, you can do one of the following:
Through the eero app menu
Tap the eero Plus option from the menu. From there, tap the blue button at the bottom to sign up.
 Network Settings
Tap on Security & Privacy and follow the provided steps.
