Internet Service Providers (ISPs) offer a variety of configurations when connecting to the internet. Like every other region, the EU has its own specifics when it comes to optimizing your eero setup. Typically those differences are based on limitations and requirements by the upstream connection. In most cases this means that an additional adjustment is needed on your ISP-provided equipment.
A general specification for the EU market is that most providers require their equipment to remain under the default settings in order to preserve the proper functioning of the service.
This can be due to various protocols that the ISP equipment uses, or other security restrictions applicable to their equipment. As of the release of eeroOS v6.6.1 and eero App version 6.13.0, eero 6 and newer now support PPPoE which is used by some ISPs in Europe. For more information on PPPoE and how to enable it, please see the our PPPoE article.
Here are some of the best practices when it comes to configuring your eero network in the EU.
Setting Up eero in the UK
A common practice in the UK is to use various authentication and security protocols on the ISP equipment. Fortunately, we are often provided with several options that can help us adjust the eero network to fully cooperate with the already established configuration.
Most service providers offer TV+Internet access packages, which means that we need to Double NAT the network in order to keep both services running. In other cases, we need to implement wireless TV boxes to the eero network, such as Sky Q for example.
There are certainly many possibilities for this market so we strongly recommend checking the dedicated article for the UK:
Most Common UK ISP's and How to Set Up eero with Them
Setting up eero in France
Most ISPs in France do not have specific requirements to set up your eero system. Some of the most common providers (Orange, Vodafone, Bouygues, Free, SFR) support some very user-friendly equipment that can easily be adjusted to cooperate better with your eero network.
Best Setup Practices for networks in France
In some cases, the ISP-provided package includes TV service. In these instances, we need to keep your ISP equipment in its default state instead of putting it in Bridge mode. Still though, disabling the wireless signal of the box is needed.
We strongly recommend disabling any Wi-Fi networks running from any other routers that you may have, and this applies to France as well.
Setting up eero in Germany
Although PPPoE is very common in Germany, some of the most common ISPs (Deutsche Telekom, Vodafone, O2) often provide the needed flexibility for eero to function properly. For instance, most modem-router combo devices provided by Deutsche Telekom or Vodafone support Bridge mode and/or disabling the Wi-Fi network of the unit.
We highly recommend checking out Best Practices for Setting up eero in Germany for more details.
For most models, there is a dedicated Wi-Fi button which you can use to easily Enable/Disable your wireless signal. If there is no such button, the service is often provided with a companion app that you can use to disable the signal and make additional changes if needed.
Setting up eero in Italy
Italy has a large variety of ISPs and services on offer - all of them work great with eero and setting up your network should not be a problem.
Please refer to the Best Practices for Setting up eero in Italy.
Setting up eero in Spain
Spain is not an exception and just as the other countries in the region most ISPs here also require PPPoE authentication or its analogs.
Most models provided by common ISPs (Movistar, Vodafone) often have a dedicated button to disable the wireless signal. This is the best scenario as the service provided is often TV+ Internet which means that putting the modem/router in Bridge (Modem) mode could affect the TV part of your service.
Best Practices for setting up eero in Spain
And as always, if you need any assistance or just want to discuss mesh and Wi-Fi - feel free to reach out to our team.
