Refer to the eero for Business FAQ if you haven’t already signed up for eero for Business.
To set up a new business network, you will first need to add the name of your business. A business name is an easy way to identify your network when you have more than one network with the same wifi name.
The business name can be the same or different from the network wifi name. Once the business name has been added, you can now set up the network.
How do I set up my network - SSID Setup?
Before you begin, make sure you have the following when setting up your eero wifi network:
- Gateway eero device: An eero device with at least 2 Ethernet ports.
- Power Cord
- Ethernet cord
- Modem
Note: Your phone or tablet will need access to cellular data and Bluetooth turned on.
To set up your network:
- Unplug your old modem and router from power. If you have any other equipment connected to your modem, unplug it and restart the modem.
- Connect your Gateway eero device to your modem using the Ethernet cable included in the box. You can use either of the ethernet ports on the back of your Gateway eero device.
- Plug your Gateway eero device into an available power outlet, then reconnect your modem to power. Your device’s status light will start flashing white.
- Select where your eero device is located.
- Give your eero wifi network a name and a password. Note: Your password must be a minimum of 8 characters and must contain special characters.
- Your eero wifi network should now be up and running.
What happens after I set up my network?
When eero for Business is enabled, a passwordless Guest Network will be created by default for use.
You can adjust these settings and set up additional business features such as multi SSIDs (i.e., Guest, Business and IoT networks) and Captive Portal.
Note: The passwordless Guest Network will have Captive Portal enabled upon creation of the network.
By enabling additional SSIDs, you will have the ability to provide different types of network access to different users (for example, visitors, employees, business critical devices).
What is the difference between Main, Guest, Business and IoT Networks?
- Main Wifi Network: Your main network can be used for a variety of purposes. This network grants access to various types of users, devices, and systems.
Guest Wifi Network (Captive Portal Network): Guest wifi access can be separated from employee wifi access via a dedicated guest wifi network. This is suitable for guest devices. It is not recommended to use this wifi network for employee devices or devices that process financial transactions such as Point of Sale devices.
- Note: The guest network should always be used to provide wifi access to third parties.
- Business Wifi Network: Using the business wifi network, any devices that process payments or financial transactions such as point of sales systems can be isolated from the rest of the network, preventing employees or guests from accessing payment or credit card data.
- IoT Wifi Network: eero’s out of the box IoT wifi network allows businesses to segregate their IoT and security devices, creating dedicated IoT control. This is suitable for security devices such as security cameras, alarm panels, sensors and other IoT devices needing to be secured or isolated from the rest of your network.
Note: While all wifi networks are isolated from each other, it is important to note that on the Guest and IoT networks, no two devices can talk to each other. This further enhances security of common types of devices that connect to guest and IoT networks.
How do I set up my Business Network?
- Tap on the Discover tab at the bottom of the eero app.
- Navigate to the Business features section of the app and select Multi SSID.
- Select Add wifi network.
- Select Add business wifi network.
- Ensure Enable wifi network is selected.
- Enter the wifi network name and password. Note: Your password must be a minimum of 8 characters and must contain special characters.
- Select Save.
- Once you are done adding your business wifi network, select the back button arrow at the top left hand side of the app.
- You will have the option to add additional wifi networks by selecting the Add wifi network option.
- To go back to the discover page, select the Discover tab at the bottom of the eero app.
How do I set up my IoT Network?
- Select Add IoT wifi network.
- Select Save.
- Once you are done adding your IoT wifi network, select the back button arrow at the top left hand side of the app.
Can I have 2 Business or 2 IoT SSIDs?
Yes. Your network can have up to 4 SSIDs. 1 Main, 1 Guest and 2 Business or 2 IoT, or 1 each of IoT and Business.
How do I set up my Guest Network with Captive Portal?
An open Guest Network with Captive Portal will be enabled by default after subscribing to eero for Business.
To edit your Guest Network with Captive Portal Settings:
- Select eero for Business.
- Select Captive Portal from the Business features section of the app. Note: This will load your guest wifi network settings, also known as your Captive Portal for your customers.
- Select your captive portal (guest network) name and password. Note: Your password must be a minimum of 8 characters and must contain special characters.
You can change the guest session duration, captive portal header and subheader, and captive portal theme. If you wish to edit your captive portal:
- Select Edit captive portal.
- Session Duration: Your captive portal enables you to set duration limits for guests’ internet access ranging from 30 minutes to 24 hours.
- Header and Subheader: Customers initiating a new connection to your guest network will be greeted with a portal you can customize, including a welcome message. If you wish to customize your portal with your logo and business terms of use, select the Contact Us button to send your logo and business terms to eero for review.
- Theme: You have the option to choose light or dark mode.
- After you have finalized your captive portal, hit Save.
- Once you are done adding your Guest Network with Captive Portal, select the back button arrow at the top left hand side of the app.
Your customers can now enjoy a seamless internet experience for your business.
What if I want to enable Guest Network with Captive Portal for an existing network?
- Navigate to the Business features section of the app and select Captive Portal.
- Access the Wifi network settings.
- Select the network you want to enable captive portal for.
- Ensure the Enable wifi network option is selected..
- Tap Enable captive portal.
Network Setup FAQs
I received an error message when adding a network: “We couldn’t update, something went wrong. Please try again later or contact support".
This can occur when you are using the same SSID as another network. An SSID is the name you assign to your network. Make sure to use unique SSIDs for each network.
I’m hitting Save when adding a wifi network, but it's not working.
Make sure to check your password length. This often occurs when you are not using a password that is 8 characters long, including special characters.
I want to filter certain content, what do I need to do?
eero for business customers can benefit from content filtering on the IoT and Captive (Guest) networks. For a full review of content filtering, please visit our content filter article.
