What is Zigbee Smart Home Hub?
The eero 6 systems are equipped with a built-in Zigbee smart home hub, eliminating the need for additional Zigbee hubs around the home. Featuring a built-in Zigbee smart home hub, the eero 6 systems connect compatible devices on your network with Alexa so you don’t need a separate Zigbee smart home hub for each device.
