What are the model numbers for eero and eero Beacon?
These are the different model numbers to identify each type of eero:
Model NumberModelDistinct Characteristics
A010001eero (1st-gen)
- Flat eero logo
- Barrel power adapter
- USB port (diagnostics)
B010001eero Pro (2nd-gen)
- Raised eero logo- USB-C power adapter
D010001eero Beacon
- Smaller form factor
- Built-in power adapter
- Nightlight
J010011eero (2nd-gen)
- Updated "cupcake" form factor
- Reset button on bottom
- 15W USB-C power supply
C01000124W USB-C power supply
- USB-C connector
C11001115W USB-C power supply
- USB-C connector
C21001127W USB-C power supply
- USB-C connector
K010011eero Pro 6
- Similar to eero Pro (2nd gen), but 3/4" taller
- 27W USB-C power supply
N010011eero 6
- Similar to eero (2nd gen), with wider base
Q010011eero 6 extender
- Same as eero 6, but without RJ45 ethernet ports
R010011eero 6+
- Similar to eero 6- 15W USB-C power supply
S010011eero Pro 6E
- Similar to eero Pro 6- 27W USB-C power supply
T010001eero PoE 6
-  Wall or ceiling mounted- Native support for PoE
- Includes mounting bracket
U010001eero PoE Gateway
- Ethernet-only PoE Gateway switch
- Black exterior casing- Includes 140W power supply
PA10111eero 7
- Wi-Fi 7-enabled
- comparable form factor to eero 6
- 2 Ethernet ports
ME10111eero Pro 7
- Wi-Fi 7-enabled
- Taller form factor compared to other eeros
- 2 Ethernet ports
V010001eero Max 7
- Wi-Fi 7-enabled
- 4 Ethernet ports
SN10001eero Outdoor 7
- Outdoor eero device
- Includes accessories for external surface mounting
- Single Ethernet port
NV14111eero PoE 7
- Wi-Fi 7-enabled
RG4U
RG4W
eero Signal 4G LTE- Backup connectivity for eero systems
- Annual eero Plus subscription required
RG5Weero Signal 5G RedCap
