Our support ticketing system will be undergoing maintenance between 3/22-3/24/25 as we perform essential maintenance to improve our services. While our phone support will remain operational during this time, customers may experience longer than usual hold times.
Getting started with eero for Business
Refer to the  eero for Business FAQ if you haven’t already signed up for eero for Business.
To set up a new business network, you will first need to add the name of your business. A business name is an easy way to identify your network when you have more than one network with the same wifi name.
The business name can be the same or different from the network wifi name. Once the business name has been added, you can now set up the network.
How do I set up my network - SSID Setup?
Before you begin, make sure you have the following when setting up your eero wifi network:
  • Gateway eero device: An eero device with at least 2 Ethernet ports.
  • Power Cord
  • Ethernet cord
  • Modem
Note: Your phone or tablet will need access to cellular data and Bluetooth turned on.
To set up your network:
  1. Unplug your old modem and router from power. If you have any other equipment connected to your modem, unplug it and restart the modem.
  2. Connect your Gateway eero device to your modem using the Ethernet cable included in the box. You can use either of the ethernet ports on the back of your Gateway eero device.
  3. Plug your Gateway eero device into an available power outlet, then reconnect your modem to power. Your device’s status light will start flashing white.
  4. Select where your eero device is located.
  5. Give your eero wifi network a name and a password. Note: Your password must be a minimum of 8 characters and must contain special characters.
  6. Your eero wifi network should now be up and running.
What happens after I set up my network?
When eero for Business is enabled, a passwordless Guest Network will be created by default for use.
You can adjust these settings and set up additional business features such as multi SSIDs (i.e., Guest, Business and IoT networks) and Captive Portal.
Note: The passwordless Guest Network will have Captive Portal enabled upon creation of the network.
By enabling additional SSIDs, you will have the ability to provide different types of network access to different users (for example, visitors, employees, business critical devices).
What is the difference between Main, Guest, Business and IoT Networks?
  • Main Wifi Network: Your main network can be used for a variety of purposes. This network grants access to various types of users, devices, and systems.
  • Guest Wifi Network (Captive Portal Network): Guest wifi access can be separated from employee wifi access via a dedicated guest wifi network. This is suitable for guest devices. It is not recommended to use this wifi network for employee devices or devices that process financial transactions such as Point of Sale devices.
    • Note: The guest network should always be used to provide wifi access to third parties.
  • Business Wifi Network: Using the business wifi network, any devices that process payments or financial transactions such as point of sales systems can be isolated from the rest of the network, preventing employees or guests from accessing payment or credit card data.
  • IoT Wifi Network: eero’s out of the box IoT wifi network allows businesses to segregate their IoT and security devices, creating dedicated IoT control. This is suitable for security devices such as security cameras, alarm panels, sensors and other IoT devices needing to be secured or isolated from the rest of your network.
Note: While all wifi networks are isolated from each other, it is important to note that on the Guest and IoT networks, no two devices can talk to each other. This further enhances security of common types of devices that connect to guest and IoT networks.
How do I set up my Business Network?
  1. Tap on the Home tab at the bottom of the eero app.
  2. Navigate to the Business features section of the app and select Multi SSID
  3. Select Add wifi network
  4. Select Add business wifi network
  5. Ensure Enable wifi network is selected.
  6. Enter the wifi network name and password. Note: Your password must be a minimum of 8 characters and must contain special characters.
  7. Select Save.
  8. Once you are done adding your business wifi network, select the back button arrow at the top left hand side of the app.
  9. You will have the option to add additional wifi networks by selecting the Add wifi network option.
  10. To go back to the discover page, select the Discover tab at the bottom of the eero app.
How do I set up my IoT Network?
  4. Select Add IoT wifi network
  7. Select Save
  8. Once you are done adding your IoT wifi network, select the back button arrow at the top left hand side of the app.
Can  I have 2 Business or 2 IoT SSIDs?
Yes. Your network can have up to 4 SSIDs. 1 Main, 1 Guest and 2 Business or 2 IoT,  or 1 each of IoT and Business.
How do I set up my Guest Network with Captive Portal?
An open Guest Network with Captive Portal  will be enabled by default after subscribing to eero for Business.
To edit your Guest Network with Captive Portal logo Settings:
  1. Open the eero app.
  2. If you have multiple business networks, select the one you wish to work with.
  3. Ensure Enable guest wifi network and Enable captive portal are toggled on.
  4. Tap Edit captive portal.
  5. Select a Session duration.
    • Note: This can be set in increments of 30 minutes, 60 minutes, 90 minutes or a maximum of 24 hours.
  6. Tap Captive portal logo.
  7. Upload a logo that will be displayed to your visitors on your captive portal.
    • Your logo should be 200x200px minimum resolution, a PNG, JPG, or JPEG file, and 5MB maximum. We recommenced uploading an image with no margins and a transparent background to allow you to easily switch between light and dark mode.
  8. You have the option to Choose File or select an image from your Photo Library.
  9. Browse your Files or Photo Library and select the logo you would like to utilize within our captive portal.
  10. Once your logo has been uploaded, you can remove, replace or view the file.
If you receive one of the below error messages upon upload of your captive portal logo, check the reason for the upload failure and attempt to upload the logo again:
  1. Unable to upload a logo.
  2. File dimension too small. Please select a file with a resolution of at least 200x200px.
  3. File too large. Please select a file below 5 MB.
To upload custom terms of use:
  5. Tap Custom terms of use and enable it
  6. Import a terms file from your file library. Please note that only .txt files are supported at this time.
  7. Click save.
Your customers can now enjoy a seamless internet experience for your business.
What if I want to enable Guest Network with Captive Portal for an existing network?
  2. Navigate to the Business features section of the app and select Captive Portal
  3. Access the Wifi network settings.
  4. Select the network you want to enable captive portal for.
  5. Ensure the Enable wifi network option is selected..
  6. Tap Enable captive portal.
Network Setup FAQs
 I received an error message when adding a network:  “We couldn’t update, something went wrong. Please try again later or contact support".
This can occur when you are using the same SSID as another network. An SSID is the name you assign to your network. Make sure to use unique SSIDs for each network.
I’m hitting Save when adding a wifi network, but it's not working.
Make sure to check your password length. This often occurs when you are not using a password that is 8 characters long, including special characters.
 I want to filter certain content, what do I need to do?
eero for business customers can benefit from content filtering on the IoT and Captive (Guest) networks. For a full review of content filtering, please visit our content filter article.
