How do I get started with eero Business?
Refer to the eero Business FAQ if you haven't already signed up for eero Business.
To set up a new business network, you'll first need to add the name of your business. A business name is an easy way to identify your network when you have more than one network with the same wifi name.
The business name can be the same or different from the network wifi name. Once the business name has been added, you can now set up the network.
How do I set up my network?
To set up your eero wifi network for the first time, follow the steps in our setup article.
What happens after I set up my network?
When eero Business is enabled, a guest network will be created by default for you to activate.
You can adjust these settings and set up additional business features such as multi SSIDs (Guest, Business and IoT networks) and Captive Portal. By enabling additional SSIDs, you'll have the ability to provide different types of network access to different users (for example, visitors, employees, business critical devices).
What's the difference between Main, Guest, Business and IoT Networks?
Main wifi Network
Your main network can be used for a variety of purposes. This network grants access to various types of users, devices, and systems.
Guest wifi Network (Captive Portal Network)
Guest wifi access can be separated from employee wifi access via a dedicated guest wifi network. This is suitable for guest devices. It's not recommended to use this wifi network for employee devices or devices that process financial transactions such as Point of Sale devices.
Note: The guest network should always be used to provide wifi access to third parties.
Business wifi Network
Using the business wifi network, any devices that process payments or financial transactions such as point of sales systems can be isolated from the rest of the network, preventing employees or guests from accessing payment or credit card data.
IoT (Internet of Things) wifi Network
eero's out of the box IoT wifi network lets businesses segregate their IoT and security devices, creating dedicated IoT control. This is suitable for security devices such as security cameras, alarm panels, sensors and other IoT devices needing to be secured or isolated from the rest of your network.
Note: While all wifi networks are isolated from each other, it's important to note that on the Guest and IoT networks, no two devices can talk to each other. This further enhances security of common types of devices that connect to guest and IoT networks.
How do I activate my Guest Network?
  1. Tap on the Settings tab in the bottom-right corner of the eero App
  2. Tap Multi SSID
  3. Tap your guest wifi name
  4. Tap the toggle button next to Enable wifi network
  5. By default, your guest network uses a password to connect. If you prefer not to use a password, tap the button next to Open network under Wifi network security
How do I set up my Business Network?
  2. Tap Multi SSID
  1. Select Add wifi network
  2. Select Add business wifi network
  3. Ensure Enable wifi network is selected
  4. Enter the wifi network name and password
Note: Your password must be a minimum of 8 characters and must contain special characters.
  1. Select Save
  2. After adding your business wifi network, select the back button arrow at the top-left corner of the app
  3. You'll have the option to add additional wifi networks by selecting the Add wifi network option
How do I set up my IoT Network?
  2. Tap Multi SSID
  3. Select Add wifi network
  4. Select Add IoT wifi network
  5. Ensure Enable wifi network is selected
  6. Enter the wifi network name and password
    • Note: Your password must be a minimum of 8 characters and must contain special characters.
  7. Tap Save
  8. After adding your IoT wifi network, select the back button arrow at the top-left corner of the app
  9. You'll have the option to add additional wifi networks by selecting the Add wifi network option
Can I have 2 Business or 2 IoT SSIDs?
Yes. Your network can have up to 4 SSIDs: 1 Main, 1 Guest and 2 Business or 2 IoT, or 1 each of IoT and Business.
How do I set up my Guest Network with Captive Portal?
An open Guest Network with Captive Portal will be enabled by default after subscribing to eero Business.
To edit your Guest Network with Captive Portal logo settings:
  1. Open the eero App
    • If you have multiple business networks, select the one you wish to work with
  2. Ensure Enable guest wifi network and Enable captive portal are toggled on
  3. Tap Edit captive portal
  4. Tap Session duration
    • Note: This can be set in increments of 30 minutes, 60 minutes, 90 minutes or a maximum of 24 hours.
  5. Tap Captive portal logo
  6. Upload a logo that will be displayed to your visitors on your captive portal
  7. You have the option to choose a file or select an image from your Photo Library
  8. Browse your Files or Photo Library and select the logo you'd like to use within your captive portal
  9. Once your logo has been uploaded, you can remove, replace or view the file
Image requirements:
  • 200x200px minimum resolution
  • PNG, JPG, or JPEG file
  • 5MB maximum
We recommend uploading an image with no margins and a transparent background to let you easily switch between light and dark mode.
What if I receive an error when uploading my image?
If you receive one of the below error messages upon upload of your captive portal logo, check the reason for the upload failure and attempt to upload the logo again:
  • Unable to upload a logo.
  • File dimension too small. Please select a file with a resolution of at least 200x200px.
  • File too large. Please select a file below 5 MB.
To upload custom terms of use:
  2. If you have multiple business networks, select the one you wish to work with
  3. Ensure Enable guest wifi network and Enable captive portal are toggled on
  4. Tap Edit captive portal
  5. Tap Custom terms of use and enable it
  6. You can use the text editor to type your terms of use, or you can import them as a file. Tap Import terms of use from file to import a file from your device’s library. Please note that only .txt files are supported at this time
  7. Tap Save in the top-right corner
Your customers can now enjoy a seamless internet experience for your business.
Frequently Asked Questions
I received an error message when adding a network: "We couldn't update, something went wrong. Please try again later or contact support."
This can occur when you're using the same SSID as another network. An SSID is the name you assign to your network. Make sure to use unique SSIDs for each network.
I'm hitting Save when adding a wifi network, but it's not working.
Make sure to check your password length. This often occurs when you're not using a password that's 8 characters long, including special characters.
I want to filter certain content, what do I need to do?
eero Business customers can benefit from content filtering on the IoT and Guest networks. For a full review of content filtering, please visit our content filter article.
