What speed is eero capable of? What about its bandwidth?
Please see the chart below for max speeds per eero device. The eero 6 extender and the eero Beacon do not have Ethernet ports and can only be added to a new or existing eero network.*
DeviceRecommended with ISP speeds up to
eero Outdoor 72.5 Gbps
eero Max 710 Gbps
eero Pro 75 Gbps
eero 72.5 Gbps
eero PoE 710 Gbps
eero PoE 61.6 Gbps
eero Pro 6E2.3 Gbps
eero 6+1 Gbps
eero Pro 61 Gbps
eero 6900 Mbps
eero Pro1 Gbps
eero550 Mbps
eero 6 Extender*500 Mbps
Beacon*350 Mbps
It’s important to keep in mind that these are the maximum speeds we’ve seen with eero, but we like to think of WiFi speed more in terms of what you can do with it. eero uses the latest standards to make sure you’re getting the speed you pay for in every corner of every room. It’s that perfect combination of speed and coverage that’s going to let you work, stream, play, or download anywhere in your home.
Here are the speeds required for some of our favorite activities:
ActivitySpeed (Mbps)
Spotify0.7
YouTube1
Netflix1.5
FaceTime3
Online gaming3.5
Google Hangout4
HD5
ULTRA HD25
