No. eero offers several models with different capabilities and features, but they're all interchangeable and work together in a network. You'll need a Gateway eero with an Ethernet port to connect to your modem, but after that, you can use any combination of eeros to extend coverage.
The currently available eeros are as follows:
The eero Max 7 is the first Wi-Fi 7 eero that supports up to 10 gigabit speeds to more of the home, while reducing latency with the addition of 320 MHz channel bandwidths. For customers who want the latest in networking technology, have hundreds of connected devices in their network, or want to maximize the usage of their provider's multi-gigabit internet plans, the eero Max 7 is the ideal choice.
eero Pro 7
The eero Pro 7 is our newest generation of tri-band Wi-Fi 7 router built for households that require constant connectivity and high speed. Supporting wired speeds up to 4.7 Gbps and wireless speeds up to 3.9 Gbps, the eero Pro 7 is made for households that use multiple smart home appliances, connected devices, and other electronics that require high data throughput and low latency.
eero 7
The eero 7 is a Wi-Fi 7 router ideal for customers with multi-gig internet plans who want an affordable way to upgrade their home network to take advantage of the newest in wireless technology. The eero 7 is capable of delivering wired speeds up to 2.3 Gbps, and wireless speeds up to 1.8 Gbps, making it well suited for 2.5 Gbps internet plans.
eero Outdoor 7
The eero Outdoor 7 is our first eero unit designed for use in outdoor environments. It brings Wi-Fi 7 and eero’s expansive wifi range outdoors, combining power and speed with durability and reliability. The eero Outdoor 7 supports wireless speeds of up to 2.1 Gbps, making it a great choice for anyone who wants to bring the power of Wi-Fi 7 to their backyard, and beyond.
eero Pro 6E
eero Pro 6E future-proofs your connectivity with hardware that powers the latest Wi-Fi 6E devices. Unlike some mesh wifi systems, eero Pro 6E does not dedicate the 6 GHz band to backhaul, allowing your Wi-Fi 6E devices to take direct advantage of the additional 6GHz bandwidth. The eero Pro 6E provides up to 2,000 sq ft of coverage per device, and supports network speeds up to 2.3 Gbps (a gigabit wired and 1.3 Gbps wireless). The eero Pro 6E is compatible with all supported previous eero models and with two auto-sensing Ethernet ports, it can be used as the gateway of an eero mesh wifi system, or a wireless extender to expand your existing eero network. Combining eero Pro 6E devices with older generation eero devices on the same network may result in reduced performance across your network. You'll also need to use a Wi-Fi 6 (or in Canada, Wi-Fi 6E) compatible connected device to enjoy the full benefits of the eero Pro 6E.
eero Pro 6
eero Pro 6 uses the power of Wi-Fi 6 to deliver fast speeds, support for 75+ connected devices, and coverage of up to 2,000 sq ft. per device. The eero Pro 6 is compatible with all of our previous eero models and with two auto-sensing Ethernet ports, it can be used as the gateway of an eero mesh wifi system, or a wireless extender to expand your existing eero network. You'll need to use a Wi-Fi 6–compatible connected device to enjoy the full benefits of the eero Pro 6.
eero 6+
eero 6+ packs a punch by supporting speeds up to a gigabit and coverage up to 1,500 sq. ft per device. eero 6+ works as a smart home hub so you can control compatible Zigbee devices with Alexa (account linking required). eero 6+ offers premium performance—without the premium price tag.
eero 6
The eero 6 Wi-Fi 6 router supports speeds up to 900 Mbps and provides coverage up to 1,500 square feet per device—so you can say goodbye to dead spots and buffering. Work, play, video conference, and stream across your home. Set up eero in minutes and get automatic updates, a built-in smart home hub, and more.
eero 6 Extender (add-on)*
The eero 6 Extender adds up to 1,500 square feet of coverage per device to your eero Wi-Fi 6 network. Boost your entertainment-grade wifi throughout your home, get automatic updates, and manage everything with the eero App.
*The eero 6 Extender does not have Ethernet ports and can only be added to an existing eero network.
eero PoE 6
The eero PoE 6 is a powerful Wi-Fi 6-enabled access point that can be mounted on a ceiling or wall to provide up to 2,000 sq ft. of coverage. Capable of supporting over 100 devices at wireless speeds of up to 1.5 Gbps, the eero PoE 6 is a great choice for expanding your network while being sleek and unobtrusive. Thanks to its native support for PoE, no additional power supply is required, providing you with greater flexibility in placing and installing the unit where you want.
eero PoE 7
The eero PoE 7 is a PoE-capable wireless router built for Wi-Fi 7. Capable of delivering wireless speeds of up to 3.9 Gbps to over 200 devices, the eero PoE 7 provides the latest in wireless networking, allowing users with PoE networks to completely blanket their home or business with tri-band wifi connectivity and speed. In addition to mounting access for walls and ceilings, the eero PoE 7 can also be mounted onto dropped ceilings using a specially designed mount.
eero PoE Gateway
eero PoE Gateway is a multi-gigabit wired gateway designed to power up to 8 eero PoE 6 devices, providing your home or business with complete wifi coverage. Thanks to its two 10 GbE and eight 2.5 PoE-capable 2.5 GbE ports, it can also provide power to a number of additional PoE devices, further increasing your flexibility by supplying up to 100W of pooled power for PoE-enabled devices.
eero Pro
eero Pro supports three wireless bands simultaneously (tri-band wifi). As the gateway of an eero mesh wifi system, the eero Pro has two auto-sensing Ethernet ports. One connects directly to the modem and the other port provides the option to hardwire devices like an Ethernet switch, printer, or video game console.
eero
eero is the little router with a big wireless footprint. This economical option still gives you the great speed and coverage across your home that you’re used to. eero offers up to 1500 sq ft of coverage per device and can be a great addition to expand an existing mesh wifi network. With the two auto-sensing Ethernet ports, it can also be used as the gateway of an eero mesh wifi system. One connects directly to the modem and the other port provides the option to hardwire devices like an Ethernet switch, printer, or video game console.
eero Beacon (add-on)*
With eero Beacon, simply plug each unit into a wall outlet to expand coverage of your existing mesh wifi network.
*The eero Beacon does not have Ethernet ports and can only be added to an existing eero network.
Are eeros interchangeable?
Yes. However, every network needs a Gateway eero with an Ethernet port to connect to your modem. The following eeros can be used as a gateway:
- eero
- eero Pro
- eero 6
- eero 6+
- eero Pro 6
- eero PoE Gateway
- eero PoE 6
- eero Pro 6E
- Ring Alarm Pro
- eero Outdoor 7
- eero 7
- eero Pro 7
- eero Max 7
- eero PoE 7
Once your Gateway eero is installed, you may use any combination of eeros to set up your network. All eeros are compatible with each other no matter when they were released.
