eero doesn’t replace your modem, it replaces your router. The first eero plugs into your existing cable or DSL modem. If you have a combination modem/router, you’ll be using that as a modem and disabling the routing function by putting it in bridge mode. (check out this article for our instructions on how to do this). Additional eeros just need power from a standard outlet.
