Can I connect wired devices to my network using an Ethernet switch?
Yes. If you would like to hardwire additional devices to your eero network, you can connect a wired switch to one of the Ethernet ports on any eero. Once you’ve connected a switch, the eero port will configure itself automatically.
Note: Always plug the switch into your eero and not directly into your modem. eero supports gigabit Ethernet (1000 / 100 / 10 mbps) but can also work with Fast Ethernet (100 / 10 mbps) equipment.
Though a Managed Switch can be made to work with the eero system, we generally recommend using Unmanaged Switches as their ease of use combines well with our system.
