TrueMesh is our patented mesh networking technology. With TrueMesh, eero devices connect wirelessly to every other eero device within range of your network. This creates a network of connections that give an eero network redundant links and the opportunity to redirect to the ideal path.
TrueMesh technology dynamically finds the ideal path for data to pass through a network, limiting interference and helping ensure you have a fast, reliable internet experience.
Additionally - on eero Pro 6, eero Pro 6E, and eero Max 7 - TrueMesh actively evaluates each connected device’s connection to the network (and available uplink bands) and picks the ideal mesh backhaul radio band dynamically per connected device to optimize performance. Based on these factors, network traffic is directed using the optimal band for each device individually rather than sending mesh traffic from all devices through the same channel simultaneously.
What are the Key Benefits of TrueMesh?
With TrueMesh, eero optimizes performance based on your network layout, connected devices, and overall network usage. This results in fast speed, efficient coverage and reliable connection. With TrueMesh, you can expect:
- Increased throughput
- Lower network/mesh latency
All access points are communicating with one another and the gateway, and traffic is routed intelligently without reliance on “hub and spoke” nodes that slow down the network. If an eero device drops offline, eero TrueMesh technology determines the ideal path among your eero devices so your signal stays strong.
