eero Pro 7
We are excited to introduce the eero Pro 7, our newest generation of tri-band Wi-Fi 7 router built for households that require constant connectivity and high speed. Supporting wired speeds up to 4.7 Gbps and wireless speeds up to 3.9 Gbps, the eero Pro 7 is made for households that use multiple smart home appliances, connected devices, and other electronics that require high data throughput and low latency.
eero pro 7 side, back front
New to eero? If you are interested in learning more about eero, check out some of our information resources:
Hardware Details
The eero Pro 7 is a tri-band Wi-Fi 7 router made for large home networks with high speed and connectivity requirements. It is capable of serving as either a primary router or as an extender for an existing eero network.
Each eero Pro 7 features two auto-sensing 5 GbE ports, enabling hardwired devices to take full advantage of internet plans up to 5 Gbps. The eero Pro 7 provides up to 2,000 sq. ft. (190 m²) of indoor coverage per unit, and can support 200+ connected devices.
Features:
  • Full support for Wi-Fi 7 (802.11a/b/n/ac/ax/be)
  • BE10800 Rating
  • 2x2x2 Antenna Array
  • Automatic Channel Selection
  • Works With Alexa
  • Zigbee-compatible smart home hub
  • Thread compatible
  • Matter compatible (controller only)
  • Supports Smart Home Hub (SHH)
  • Can support 200+ devices
Device Name eero Pro 7
Use Case Gateway or Indoor Extender
Placement Sitting on a flat surface
Size
7.1 x 5.77 x 3.09 in.
(180 x 146 x 78 mm)
Connectivity
Tri-Band
2x2/2x2/2x2 SU-MIMO
2.4 GHz: 2x2
5 GHz: 2x2
6 GHz: 2x2
Two 5GbE ports
Channel Width 20, 40, 80, 160, 240, 320 MHz
Power eero 27W PSU, 100-240V AC, 50/60 Hz
MLO Support
A new feature of the eero Pro 7 is Multi-Link operation (MLO) support, which can reduce latency and improve connectivity and speed for Wi-Fi 7 devices when compared to standard operation. Combined with Wi-Fi 7 support and eero’s continuous firmware updates, the eero Pro 7 enables home networks to take full advantage of the newest and most powerful wifi technology.
Check out our dedicated article on Multi-Link Operation for more information.
Included in Package
For eero 7 devices that are sold individually, each package includes the following:
  • 1 eero Pro 7 router
  • 1 27W USB-C power adapter
  • 1 CAT6a Ethernet cable
Additional FAQ
Can I use eero Pro 7 with my existing eero hardware?
Yes. The eero Pro 7 is fully backwards compatible with previous generations of eero hardware, and can also be used together with current eero Wi-Fi 7 hardware, such as the eero Max 7 and eero Outdoor 7 (US/CA only).
Does eero Pro 7 work with eero Built-In?
The eero Pro 7 is compatible with eero Built-In on select Amazon Echo devices. Refer to our guide on eero Built-In for more information on how to get started.
What do I need to set up my eero Pro 7?
Similar to other eero products, the eero Pro 7 requires the use of the Android or iOS eero app for setup and network management. When setting up an eero Pro 7, be sure to place the device on a raised, flat surface, away from reflective surfaces like metal, mirrors, or glass. For more information on setting up your eero, refer to our general setup guide.
Is eero Pro 7 compatible with eero subscription services?
The eero Pro 7 is compatible with eero Plus, eero Business, as well as eero Service Providers.
What is the warranty for eero Pro 7?
The eero Pro 7 is backed by a limited 3-year warranty, on top of eero’s extensive phone and email support. For more information on our limited warranty, please see What is eero’s warranty?
Where can I find additional safety, compliance and recycling information?
Additional safety, compliance, recycling, and other important information regarding your device can be found at eero.com/compliance.
