We are excited to introduce the eero 7, a Wi-Fi 7 router ideal for customers with multi-gig internet plans who want an affordable way to upgrade their home network to take advantage of the newest in wireless technology. The eero 7 is capable of delivering wired speeds up to 2.3 Gbps, and wireless speeds up to 1.8 Gbps, making it well suited for 2.5 Gbps internet plans.
New to eero? If you are interested in learning more about eero, check out some of our information resources:
- What is required to setup eero?
- Does eero replace my Internet Service Provider?
- Can I use eero with my current ISP/modem?
- How do I set up eero?
- Where should I place my eeros?
Hardware Details
The eero 7 is a dual-band Wi-Fi 7 router built to provide speed and performance to customers that browse, stream, study, or work at home. It is capable of serving as either a primary router or as an extender for an existing eero network.
Each eero 7 features two auto-sensing 2.5 GbE ports which deliver wired speeds up to 2.5 Gbps, with 2.4 and 5 GHz antennas delivering wireless speeds up to 1.8 Gbps. The eero 7 provides up to 2,000 sq. ft. (190 m²) of indoor coverage per unit and can support 120+ devices.
Features:
- Full support for Wi-Fi 7 (802.11a/b/n/ac/ax/be)
- BE5000 Rating
- 2x2 Antenna Array
- Automatic Channel Selection
- Works With Alexa
- Zigbee-compatible smart home hub
- Thread compatible
- Matter compatible
- Supports Smart Home Hub (SHH) and is Matter compliant
- Can connect 120+ devices
Device Name |
eero 7 |
Use Case |
Gateway or Indoor Extender |
Placement |
Sitting on a flat surface |
Size |
5.12 x 5.12 x 2.52 in. (130 x 130 x 64 mm) |
Connectivity |
Dual-Band 2x2/2x2 SU-MIMO 2.4 GHz: 2x2 5 GHz: 2x2 Two 2.5GbE ports |
Channel Width |
20, 40, 80, 160, 240 MHz |
Power |
eero 15W PSU, 100-240V AC, 50/60 Hz |
MLO Support
A new feature of the eero 7 is Multi-Link operation (MLO) support, which can reduce latency and improve connectivity and speed for Wi-Fi 7 devices when compared to standard operation. Combined with Wi-Fi 7 support and eero’s continuous firmware updates, the eero 7 enables home networks to take full advantage of the newest and most powerful wifi technology.
Check out our dedicated article on Multi-Link Operation for more information.
Included in Package
For eero 7 devices that are sold individually, each package includes the following:
- 1 eero 7 router
- 1 15W USB-C power adapter
- 1 CAT5e Ethernet cable
Additional FAQ
Can I use eero 7 with my existing eero hardware?
Yes. The eero 7 is fully backwards compatible with previous generations of eero hardware, and can also be used together with current eero Wi-Fi 7 hardware, such as the eero Max 7 and eero Outdoor 7 (US/CA only).
Does eero 7 work with eero Built-In?
The eero 7 is compatible with eero Built-In on select Amazon Echo devices. Refer to our guide on eero Built-In for more information on how to get started.
What do I need to set up my eero 7?
Similar to other eero products, the eero 7 requires the use of the Android or iOS eero app for setup and network management. When setting up an eero 7, be sure to place the device on a raised, flat surface, away from reflective surfaces like metal, mirrors, or glass. For more information on setting up your eero, refer to our general setup guide.
Is eero 7 compatible with eero subscription services?
The eero 7 is compatible with eero Plus, eero for Business, as well as eero for Service Providers.
What is the warranty for eero 7?
The eero Pro 7 is backed by a limited 3-year warranty, on top of eero’s extensive phone and email support. For more information on our limited warranty, please see What is eero’s warranty?
