Introducing eero PoE 6
eero PoE 6
eero PoE 6 is eero’s first ceiling/wall-mountable Wi-Fi 6 access point. eero PoE 6 is a Wi-Fi 6 PoE access point that can provide up to 2000 sqft (190 m2) of coverage. It can support 100+ devices. It supports 160 MHz channels and wireless speeds up to 1.5 Gbps, and can go almost anywhere ethernet cable can be pulled—making it easy to flush-mount to ceilings and walls giving you optimal Wi-Fi coverage.
Because it utilizes Power over Ethernet cables, eero PoE 6 doesn’t need a separate power supply. It can be easily attached to a ceiling or wall to maximize Wi-Fi coverage throughout your home.
You can learn more about eero PoE 6 set up with the eero PoE 6 installation guide.
eero PoE 6 Technical Specifications
Wi-Fi coverage
Covers up to 2000 sqft ( 190 m2)
Type
Wireless access point
Wireless network speed
Best for gigabit+ internet speeds
Wi-Fi standard
Wi-Fi 6 (802.11ax), supporting 160 MHz channels and compatible with older Wi-Fi standards
Number of Wi-Fi radios
2; dual-band (2.4 and 5 GHz)
Ethernet ports
1 auto-sensing 2.5 Gigabit PoE port, RJ-45
1 auto-sensing Gigabit port, RJ-45
Placement
Ceiling / wall mount
