What is eero PoE 6?
eero PoE 6 is eero’s first ceiling/wall-mountable Wi-Fi 6 access point. eero PoE 6 is a Wi-Fi 6 PoE access point that can provide up to 2000 sqft (190 m2) of coverage. It can support 100+ devices. It supports 160 MHz channels and wireless speeds up to 1.5 Gbps, and can go almost anywhere ethernet cable can be pulled—making it easy to flush-mount to ceilings and walls giving you optimal Wi-Fi coverage.
eero PoE 6 can be powered in two ways:
- PoE (Power over Ethernet): No separate power adapter needed, for more information on PoE, see What is PoE?
- Power adapter: Can be used instead of PoE, to find a compatible power adapter, see eero Power Adapters and Ethernet Cables
This flexibility makes it easy to install eero PoE 6 in locations where PoE infrastructure isn't available, while still taking advantage of ceiling or wall mounting for optimal Wi-Fi coverage throughout your home.
Note: For setup instructions, see the eero PoE 6 installation guide.
eero PoE 6 Technical Specifications
Wi-Fi coverage |
Covers up to 2000 sqft ( 190 m2) |
Type |
Wireless access point |
Wireless network speed |
Best for gigabit+ internet speeds |
Wi-Fi standard |
Wi-Fi 6 (802.11ax), supporting 160 MHz channels and compatible with older Wi-Fi standards |
Number of Wi-Fi radios |
2; dual-band (2.4 and 5 GHz) |
Ethernet ports |
1 auto-sensing 2.5 Gigabit PoE port, RJ-45 1 auto-sensing Gigabit port, RJ-45 |
Placement |
Ceiling / wall mount |
