Managing Client Devices
The eero app is designed to easily view and manage all the connected client devices on a network. In order for a device to join a network, it will need to be added using the WiFi login credentials or via an Ethernet cable.
Devices are shown on the app's home page, located beneath the eero status summary. Tapping on Online or Offline will quickly access the Devices tab. Here, you can apply filters to more easily identify devices on your network. Filter options include:
You can also use the search bar at the top of the Devices tab to locate a specific device by searching for its name, IP or MAC address. |
