eero Power Adapters and Ethernet Cables
Whether you’ve misplaced your power adapter or Ethernet cable, or just need additional ones, we’ve got you covered. eero now offers several different USB-C power adapters and Ethernet cables for purchase on Amazon.com (U.S. only).
Power adapters
Please reference the table below for a list of compatible eero devices for each power adapter. eero power adapters have been tested for compatibility with the select eero devices listed below. We recommend using eero-certified power adapters with eero devices for reliable performance.
Note: Purchasing a power adapter with higher wattage will not increase the range of wifi coverage.
15W USB-C power adapter
27W USB-C power adapter
45W USB-C power adapter
140W USB-C power adapter
30W Outdoor PoE+ power adapter
An image of the eero 15W USB-C power adapter.
An image of the eero 27W USB-C power adapter.
An image of the eero 45W USB-C power adapter.
An image of the eero 140W USB-C power adapter.
An image of the eero 30W outdoor PoE+ power adapter.
15W USB-C
power adapter
27W USB-C
power adapter
45W USB-C
power adapter
140W USB-C
power adapter
30W Outdoor PoE+
power adapter
Plug type Type A Type A Type A Type B Type B
Compatible devices
eero
eero 6
eero 6+
eero PoE 6
eero 7
eero
eero 6
eero 6+
eero Pro
eero Pro 6
eero Pro 6E
eero PoE 6
eero 7
eero Pro 7
eero PoE 7
eero
eero 6
eero 6+
eero Pro
eero Pro 6
eero Pro 6E
eero PoE 6
eero PoE Gateway*
eero 7
eero Pro 7
eero
eero 6
eero 6+
eero Pro
eero Pro 6
eero Pro 6E
eero PoE 6
eero PoE Gateway
eero 7
eero Pro 7
eero Outdoor 7
Input voltage
100–240V~0.45A,
50/60Hz
100–240V~0.65A,
50/60Hz
100–240V~1.20A,
50/60Hz
100–240V~2.5A,
50/60Hz
100–240V~2.5A,
50/60Hz
Output voltage 5.0V⎓3.0A, 15.0W
5.0V⎓3.0A, 15.0W
9.0V⎓3.0A, 27.0W
5.0V⎓3.0A, 15.0W
9.0V⎓3.0A, 27.0W
15.0V⎓3.0A, 45.0W
5.0V⎓3.0A, 15.0W
9.0V⎓3.0A, 27.0W
15.0V⎓3.0A, 45.0W
20.0V⎓5.0A, 100.0W
28.0V⎓5.0A, 140.0W
56V, nominal 48V system
*When used as a non-POE switch.
Power adapters for your Ring Alarm Pro can be requested by contacting Ring.
Ethernet cables
To better support your networking needs, most eero wifi systems come with an Ethernet cable included in the packaging. Should you need additional or replacement Ethernet cables, you can buy eero-branded Ethernet cables in different colors and lengths on Amazon.com (U.S. only). All cables are available for purchase in 1-packs and 5-packs.
Ethernet cable supported standard Colors Available lengths Material Throughput
CAT5e
White 3 ft (0.91 m) Elastomer Supports speeds up to 1 Gbps
CAT6a
Arctic White
Titanium Black
Midnight Blue
6 in (0.15 m)
1 ft (0.30 m)
3 ft (0.91 m)
5 ft (1.52 m)
10 ft (3.05 m)
Double-braided nylon Supports 10 gigabit+ speeds
eero CAT6a and CAT5e Ethernet cables can be used with all eero devices—as well as with ‎laptop and desktop computers, gaming consoles, smart TVs, security cameras, printers, adapters, servers, modems, switches, and more. Based on supported speeds, recommended product pairings with eero devices can be found below.
Recommended product pairing
Product Amazon eero CAT5e Ethernet cable Amazon eero CAT6a Ethernet cable
eero X X
eero 6 X X
eero 6+ X X
eero Pro X X
eero Pro 6 X X
eero Pro 6E X X
eero PoE 6 X X
eero PoE Gateway X
eero Max 7 X
