What is Block & Allow Sites?
Block & Allow Sites is an eero Plus feature that lets you manually block or allow specific websites and domains. You can apply settings to your entire network or to individual Profiles.
Note: Content Filters block broad categories. Block & Allow Sites gives you control over individual domains.
How do I block or allow a site?
You have two options: apply settings to your entire network, or customize them for a specific Profile.
For your entire network
  1. On the eero App Home tab, tap Security & privacy to see a list of eero Plus features
  2. Tap the list to open the eero Plus page
  3. Tap Network controls
  4. Tap Block & Allow Sites
  5. Tap Add Blocked Site to add a blocked domain, or switch to Allowed, and tap Add Allowed Site to add an allowed domain
  6. Type in the desired site or domain under Domain
  7. Tap the Network toggle button so the domain is blocked/allowed on your entire eero network
  8. Once you’re ready, tap Save
For a Profile
  1. On the eero App Home tab, tap the Profile you want to block/allow a domain for
  2. Tap Block & Allow Sites
  3. Tap Add Blocked Site to add a blocked domain, or switch to Allowed, and tap Add Allowed Site to add an allowed domain
  4. Type in the desired site or domain under Domain
  5. Tap the Network toggle button so the domain is blocked/allowed on your entire eero network
  6. Once you’re ready, tap Save
How do I delete a site from the Block & Allow Sites list?
You can delete sites from your entire network or from a specific Profile.
  5. Tap the desired domain in the Blocked or Allowed list
  6. Tap Delete Site
  7. On the pop-up Are you sure you want to delete this site? tap Delete Site again to confirm
For a Profile
  1. On the eero App Home tab, tap the Profile you want to update
  3. Tap the desired domain in the Blocked or Allowed list
  4. Tap Delete Site
  5. On the pop-up Are you sure you want to delete this site? tap Delete Site again to confirm
How do domains work in Block & Allow Sites?
Domains are based on their Fully-Qualified Domain Name (FQDN). You can manage domains at any level of the hierarchy.
Note: Allowed Sites always take priority over Content Filters and Blocked Sites.
Domain Examples
  • example.com — Affects the entire domain
  • subdomain.example.com — Affects only that subdomain
  • org — Affects all .org domains
Common Mistakes
  • www.example.com
    • Enter example.com instead. "www." only blocks that subdomain.
  • https://example.com
    • Enter example.com instead. URLs aren't accepted — use FQDNs.
  • example.com/page
    • Enter example.com instead. Pages are removed automatically.
  • *.org
    • Enter org instead. Just enter the TLD name.
FAQ
What is an alias?
Some domains have aliases, known as CNAMEs (Canonical Name records). When adding a domain to your Allowed list, we'll prompt you to add any detected CNAMEs. Adding these helps ensure the site works as expected.
Why do my Block & Allow Sites settings take time to apply?
Changes usually take effect within seconds, but may be delayed due to:
Cached data — Your browser, device, or network may store cached data for minutes or hours. This is more likely if you've recently visited the site. Clearing your browser cache can help.
Why isn't a site fully blocked?
Popular sites often use multiple domains, so you may need to block additional domains to fully restrict access. Some devices use unique domains, which can cause different behavior.
