Introducing eero 6+
The eero 6+ delivers gigabit performance at an affordable price, providing premium mesh wifi performance without the premium price tag. Covering up to 1,500 square feet, the eero 6+ brings the power of Wi-Fi 6 to your home network, allowing you to work, stream, or video chat at the same time.
image of eero 6+ from the front and the back
New to eero? If you are interested in learning more about eero, check out some of our information resources:
Hardware Details
The eero 6+ is a dual-band, gigabit router built from the ground up to support Wi-Fi 6. Supporting bandwidth channels up to 160 MHz, it is ideal for users with highly active networks, with the ability to handle up to 75+ simultaneous connected devices. As with other eero hardware, it can be used as either a primary router, or as a mesh access point for an existing eero network.
  • Full support for Wi-Fi 6 (IEEE802.11a/b/g/n/ac/ax)
  • Supports wired or wireless speeds up to 1 Gbps
  • AX3000 rating
  • 2x2 Antenna Array
  • Automatic Channel Selection
  • Works With Alexa
  • Zigbee controller
  • Thread compatible
  • Matter controller
  • Supports Smart Home Hub (SHH)
Hardware Specifications
Device Name eero 6+
Use Case Wired or wireless access point
Placement Countertop or flat surface
Size 3.9 x 3.8 x 2.6 in
( 99.4 x 97 x 65.8 mm)
Connectivity Dual-Band
2x2/2x2 SU-MIMO
2.4 GHz: 2x2
5 GHz: 2x2
2 auto-sensing 1 GbE ports
Channel Width 20, 40, 80, 160 MHz
Power 100-240V AC, 50-60 Hz
Included in Package
For eero 6+ devices that are sold individually, each package contains the following:
  • 1 eero 6+
  • 1 Power Adapter
  • 1 Ethernet cable
Additional FAQ
Can I use the eero 6+ with my existing eero hardware?
The eero 6+ is fully compatible with existing eero hardware, and can be used as an access point for an existing network, or as a standalone router..
What do I need to set up my eero 6+?
Similar to other eero products, the eero 6+ requires the use of the Android or iOS eero App for setup and network management.
Is eero 6+ compatible with eero subscription services?
The eero 6+ is compatible with eero Plus as well as eero for Business (EB).
What is the warranty for eero 6+?
The eero 6+ is backed by a limited 1 year warranty, on top of eero’s extensive phone and email support. For more information about our limited warranty, please see What is eero’s warranty?
