How do I set up eero with Vodafone UK?
Vodafone devices don't support bridge mode or modem-only mode, so you have two setup options: Double NAT configuration or putting your eero network in bridge mode.
How do I set up eero in Double NAT configuration?
Connect the Gateway eero to your Vodafone Wi-Fi Hub, follow the instructions from the eero app, and complete the setup. Once your eero network is online, disable the Vodafone Hub's Wi-Fi signal to avoid interference.
Using the Vodafone Broadband app:
  1. Open your Vodafone Broadband app
  2. On the Dashboard, find the Main Wi-Fi tile
  3. Tap the toggle to switch it off
Using the Vodafone Wi-Fi Hub dashboard:
Alternatively, you can manage the internet and Wi-Fi settings on your Vodafone Wi-Fi Hub by first connecting to the device via Ethernet or Wi-Fi, logging in to the dashboard, and clicking Wi-Fi on the top menu. You can access the dashboard by typing http://vodafonewifihub or 192.168.1.1 into your browser.
How do I set up eero in bridge mode?
Follow the steps from our bridge mode guide to set up your eero network in bridge mode. You still need to disable the Vodafone Hub's Wi-Fi signal using the steps above.
