Setting Up eero with Vodafone UK
Setting up your eero network with Vodafone requires a slightly different configuration due to the fact that none of their devices support either Bridge mode or Modem-only mode.
The first option is to set up your eeros in a Double NAT configuration. All you need to do is to connect the Gateway eero to your Vodafone WiFi Hub, follow the instructions from the app and complete the setup. Once ready, it is recommended to stop the Wi-Fi signal of the Vodafone box so that no interference occurs. Here is how to do so:
  1. Open your Vodafone Broadband app.
  2. On the Dashboard find the Main Wi-Fi tile.
  3. Tap the toggle to switch it off.
  • Alternatively, you can manage the internet and Wi-Fi settings on your Vodafone Wi-Fi Hub by first connecting to the device via Ethernet or Wi-Fi, logging in to the dashboard and clicking 'Wi-Fi' on the top menu. You can access the dashboard by typing http://vodafonewifihub or 192.168.1.1 into your browser.
If you have difficulties with turning off the Wi-Fi, reach out to Vodafone’s support team for further assistance.
The second option is to set up your eero network in Bridge mode. Follow the steps from our bridge mode guide to do so. In this case you would still need to turn off the Wi-FI of the Vodafone device, so follow the steps above to do so.
