¿Puedo montar mi eero en una pared o en el techo?
You can mount eeros on a wall or ceiling without major issues. eeros work best when placed right-side-up on a flat surface (and eero Beacons in a vertical wall outlet). However, you can mount eeros on a wall or other surface if desired.
If you have an eero Outdoor 7*, you will find accessories included in the packaging for mounting the device on a variety of surfaces. For more information on mounting and other installation instructions, see our eero Outdoor 7 Installation Guide.
If you wish to mount a non-outdoor 7, non-PoE 6 unit, keep in mind that we don't have any official recommendations on mounting solutions. We do have a couple of things to consider:
  • Don't use any mounts made out of metal. This will potentially cause interference and cause issues with your WiFi.
  • When mounting your eeros, make sure they are secure. The last thing we want is eeros falling, hurting both you and your eero.
  • eero PoE 6 units should be mounted using the provided device cushions.
*Only available in US and Canada
