How do I see how much bandwidth my devices are using?
Curious how much bandwidth the devices on your network are using at any given time? Through the eero app, you can view real-time data consumption by following the instructions below:
iOS Users:
  • Open the eero app
  •  Tap the Device Category, the Device is located under (Computer, Personal, Entertainment, Home and Other)
  • Tap the Device
  • The Device Bandwidth usage is listed under Activity
  • If the Device is Idle it will show the Last Active time
Android Users:
  • Open the eero app
  • Tap the connected devices button. You can also view device usage by tapping the devices on your home screen.
Each device currently on your network will show the connection strength it has to your eeros and its current bandwidth usage. You can see the amount of data that device is downloading and uploading at any given time. If your device is connected to the network but isn’t currently using bandwidth, it will show an Idle state. You can also find this information on the details page of any of your devices.
Note: Local network traffic, such as downloading movies from a local media server, won’t factor into these usage numbers.
