Sure! eeros work best when placed right-side-up on a flat surface (and eero Beacons in a verticle wall outlet). However, you can mount eeros on a wall or other surface if desired.
With that said, we don't have any official recommendations on mounting solutions. We do have a couple of things to consider:
- Don't use any mounts made out of metal. This will potentially cause interference and cause issues with your WiFi.
- When mounting your eeros, make sure they are secure. The last thing we want is eeros falling, hurting both you and your eero.
Find a great solution to recommend to others? We'd love to see them in our community!
