IPv6 is the latest version of the Internet Protocol (IP). It ensures information sent through the internet reaches the correct destination. IPv6 is gradually replacing the previous IPv4 standard. It introduces advanced features that can make the internet faster and more secure.
IPv6 addresses use both letters and numbers, unlike older IPv4 addresses. This is crucial to allow many billions of devices to exist at the same time on the internet.
For devices talking to each other on your home network, IPv6 uses "link-local" addresses. Your router assigns these addresses. For devices connecting to the internet, IPv6 uses "global" addresses. Your internet company assigns these addresses.
Does eero support IPv6?
Yes, eero supports IPv6. Your main eero will automatically assign link-local addresses to devices as they join your network. It's common for eeros and devices to request more than one link-local address.
If your internet provider supports global IPv6 addresses, you can enable them in the eero app with the IPv6 feature.
How do I enable IPv6?
To enable IPv6, take the following steps:
- In the eero app, tap the Settings tab in the bottom-right corner
- Tap Advanced networking
- Tap IPv6
- Tap the toggle button
Once enabled, your network will restart automatically to save the new setting. If you'd like to disable IPv6, follow the same steps as above.
How do I find my eero's IPv6 address?
To find the IPv6 address of your eero:
- Tap its location nickname on the Home tab
- On the eero details page, tap IP addresses to see your eero's IPv4 and IPv6 addresses
How do I find my device's IPv6 address?
To find the IPv6 address of one of your connected devices:
- Locate the device under Devices in the Home tab, or search for it on the Devices tab
- Tap the device's name
- Tap IP addresses to see your device's IPv4 and IPv6 addresses
How do I set custom IPv6 DNS name servers?
As of app version 2.24.0, it's possible to set custom IPv6 name servers. Follow the steps shown in Setting up custom DNS servers with eero if you would like to use a custom IPv6 name server.
