A Network Nickname is a custom label that helps you distinguish between multiple networks in your eero app. For example, if you have a guest house with its own network, you can name one "Guest House" and the other "Main House" — even if both share the same SSID.
How do I set up Network Nicknames?
To set up a Network Nickname:
- Open the eero App, and tap the Settings tab in the bottom-right corner
- Tap Nickname & location
- Set a nickname for your network
- Tap Save when you’re ready
How do I switch between networks?
You'll see each network's nickname underneath its SSID. To switch between networks:
- Return to the Settings tab
- Tap the
(more options icon) in the top-right corner
- Tap Switch network
- Tap the network you’d like to view
