eero currently supports both Android and iOS. Your device must also support BLE, so Bluetooth hardware versions earlier than 4.0 aren’t supported.
iOS requirements:
- Device running iOS 12 or later
Android requirements:
- Device running Android 7.0 or later (tablets included)
In addition to the above requirements, you'll need a data connection on your device to set up your eero network. Once you're set up, you can manage your network over an Internet connection.
