You can add as many eeros , eero pros and eero Beacons as you need to your network. With eeros (1st generation, eero Pro and eeros), you can have them join your network wirelessly or over an Ethernet connection. eero Beacons will always join your network wirelessly.
To replace an eero on your network:
- Open the eero app
- Tap the blue plus icon on the top right
- Tap Add or Replace eero Devices
- Tap Replace eero Device
- Select which eero you want to replace
- Follow the setup instructions to complete the replacement
To add eeros to your existing network:
- Open the eero app
- Tap Add eero Device
- Follow the setup instructions to complete the installation
To remove eeros from your existing network:
- Open the eero app
- Tap the eero you would like to remove
- Tap Advanced
- Tap Remove "name" eero
- Tap Remove from Network at the bottom of the screen
