On the front of your eero, there is a LED status light. When everything is running correctly, your eero's light will be solid white (unless you have turned it off). If your LED is in a different state, including a different color or is blinking/flashing, please refer to the list below:
| State | LED Behavior |
| No Power or LED Disabled | ⬤ No Light |
| Online | ⬤ Solid White |
| Connecting | ⬤ Blinking White |
| Ready for Setup | ⬤ Solid Blue |
| Bluetooth Pairing | ⬤ Blinking Blue |
| Using Backup Internet | ⬤ Solid Aqua |
| Identifying Zigbee Devices | ⬤ Blinking Aqua |
| Multiple eero devices detected | ⬤ Blinking Green |
| Power Saving | ⬤ Solid Green |
| Power Supply Problem | ⬤ Yellow/Orange Light |
| Offline | ⬤ Solid Red |
| Resetting | ⬤ Blinking Red |
Note: The meaning of the colors used by eero Signal’s LED differ from the table above. See eero Signal Setup Guide for more information.
