What do the colors of the LED light on my eero mean?
On the front of your eero, there is a LED status light. When everything is running correctly, your eero's light will be solid white (unless you have turned it off). If your LED is in a different state, including a different color or is blinking/flashing, please refer to the list below:
tags: white, red, blue, yellow, green
