You can create and manage multiple networks under your eero account using eero’s Switch Network feature. This allows you to manage the settings of each network individually, or set up an entirely new network should the need arise.
How do I add additional networks to my existing account?
If you already have an eero account and network set up, you can follow these steps to create additional networks:
- Open the eero App, and tap Settings in the lower-right corner
- Tap the
(three dots icon) in the upper-right corner
- Tap Create a network
- This will bring you to the Set up eero network screen, which will walk you through the setup process to create your new network. For more information, see How do I set up eero?
How do I switch to my other networks?
To switch between the eero networks on your account:
- Tap the
- Tap Switch network. This will open a list of all the eero networks own and you have been invited to manage via eero Multi-Admin
- Tap the network you would like to switch to
