If your Xbox is giving you an error code that says "Strict" or "Moderate", we recommend making sure that you have toggled UPnP to On (the toggle will be green). To do so, take the following steps:
- Open the eero app
- Tap the Settings icon in the bottom right corner
- Tap Advanced
- Tap UPnP and toggle it to On
If you continue to see the error message, you should open the following ports in your eero app to solve the issue:
Protocol |
Port(s) to Open |
UDP |
88, 500, 3544, 4500 |
TCP |
80 |
UDP & TCP |
3074, 53 |
You can accomplish this from the mobile app by doing the following:
- Tap Advanced
- Tap Reservations and Port Forwarding
- Tap Add a reservation
- Tap on your Xbox from the device list
- Tap Open a port and follow the prompts for each of the ports you wish to forward
After you've taken these steps, you're ready to get back out there and show you are the best Master Chief.
Still having trouble? Feel free to give us a call at 1-877-659-2347 or contact us and we'll get it all sorted out!
