Scheduled pauses let you control when devices in a profile can access the internet. When a schedule is active, devices in that profile are automatically paused. They're restored at the end of the schedule period.
If you want to restrict internet access on an individual device, see Manual Pauses.
How do I set schedules?
- On the eero App Home tab, tap the profile you want to set a schedule for
- Tap Add a scheduled pause to open the Edit Schedule page
- Update the Schedule name, Start time, End time, or Frequency for the scheduled pause
- Tap Save in the top-right corner to activate the schedule
How do I modify schedules?
- Edit the Schedule name, Start time, End time, or Frequency
- Tap Save, the changes will take effect immediately
How do I disable a schedule?
- Tap the toggle button next to Schedule
Note: The schedule pauses won't restart until the toggle button is tapped again
How do I delete a schedule?
- Tap Delete schedule at the bottom of the page
- On the ”Are you sure you want to delete this schedule?” message, tap Yes
Note: If the scheduled pause was active when you deleted it, all devices associated with the profile will be unpaused
Can I override a schedule?
Yes. Tap the paused profile name and select Resume profile to restore network access until the next scheduled pause. You'll see "Paused" below the profile name when a schedule is active.
How do I set my network timezone?
We use your network timezone to accurately time your daily schedules.
To set your network timezone:
- Open the eero App, and tap Settings in the bottom-right corner
- Tap Nickname & location
- Tap Timezone at the bottom of the page
- Select the proper timezone for your network, the changes will take effect immediately
