If you'd be interested in taking your eeros out of bridge mode, you can easily do so by following the instructions below:
- Open the eero app and tap Settings (bottom right corner)
- Tap Advanced
- Tap DHCP & NAT
- Switch your selection from Bridge to Automatic (recommended) or Manual (for those running static IP)
- Tap the Save button in the top right corner
If you run into any trouble with unbridging your eeros, you can always contact our support team.
