By putting your eero network into bridge mode, you can continue managing your network through your existing router. While this approach is necessary for a small subset of customers with specific network configurations, we generally don’t recommend it because it will cause you to lose access to some of eero's advanced features. Specifically, you'll lose access to the following:
- Family Profiles
- Device bandwidth usage details
- Device blocking
- Advanced network settings management through the eero app
- Apple HomeKit Secure Router
If you can avoid bridging your eeros, we recommend it. To read more about other network configuration options, please review the following:
Note: If your network configuration does require you to bridge your eeros, rest assured you'll still experience all of the speed and stability benefits of TrueMesh.
