Low Power Standby and WiFi Off
eero supports two special modes that reduce power consumption or disable wireless connectivity while keeping your device operational.
How do I enable WiFi Off mode?
WiFi Off mode temporarily disables wifi on your eero but keeps wired Ethernet active.
To enable WiFi Off mode:
  1. Once your eero is set up, tap the reset button 8 times.
  2. Your eero will reboot, indicated by a flashing white LED.
  3. Your eero is now in WiFi Off mode.
To return to normal wifi mode, tap the reset button once, or unplug your eero from power.
How do I enable low power standby mode?
Low power standby mode reduces power consumption while keeping your eero ready to activate.
To enable low power standby mode:
  1. Once your eero is set up, tap the reset button 10 times.
  2. Your eero will immediately enter low power standby mode and the LED will turn off.
  3. Your eero is now in low power standby mode.
To return to normal wifi mode, unplug your eero from power, then plug it back in.
