eero PoE 7
The eero PoE 7 is a wireless router with built-in support for Power-over-Ethernet (PoE) and Wi-Fi 7 technology. With improved performance capabilities and a slim, compact form factor the eero PoE 7 is designed to be mounted on a variety of surfaces. The eero PoE 7 allows you to bring the power of Wi-Fi 7 to cover your home or business with fast, reliable wifi. Check out our guide on eero PoE support for more information about PoE. For setup instructions, see the eero PoE 7 installation guide. Professional installation recommended
Top of the eero PoE 7 Side view of the eero PoE 7 Back view of the eero PoE 7
New to eero? If you are interested in learning more about eero, check out some of our information resources:
Hardware Details
The eero PoE 7 is a tri-band Wi-Fi 7 router designed to function as a wireless access point for a PoE-based network. It is built with high performance and coverage requirements in mind, allowing PoE users to completely cover their home or business with tri-band wifi connectivity and speed.
Each eero PoE 7 is equipped with one 10 GbE port and one 10 GbE PoE+ port capable of supporting wired speeds up to 9.4 Gbps while broadcasting wireless speeds up to 3.9 Gbps. The eero PoE 7 provides up to 2,000 sq. ft. (190 m²) of indoor coverage per unit, and can support 200+ connected devices.
  • Full support for Wi-Fi 7 (802.11a/b/n/ac/ax/be)
  • BE10800 Rating
  • 2x2x2 Antenna Array
  • Automatic Channel Selection
  • Works With Alexa
  • Bluetooth Low Energy 5.0
  • Thread/Zigbee (802.15.4 radio)
  • Matter (controller only)
  • Can support 200+ devices
Hardware Specifications
Device Name eero PoE 7
Use Case Wired or wireless access point, wired infrastructure necessary
Placement Ceiling/wall mounted
Size
8.26 x 8.26 x 1.69 in.
(209.8 x 209.8 x 42.9 mm)
Connectivity
Tri-Band
2x2/2x2/2x2 SU-MIMO
2.4 GHz: 2x2
5 GHz: 2x2
6 GHz: 2x2
One 10 GbE PoE+ port
One 10 GbE port
Channel Width 20, 40, 80, 160, 240, 320 MHz
Power PoE+ 25.5W (802.3at) or 27W USB-C power adapter (sold separately), 100-240V AC, 50/60 Hz
Included in Package
For eero PoE 7 devices that are sold individually, each package contains the following:
  • 1 eero PoE 7
  • 1 mounting bracket
  • Mounting accessories
Additional FAQ
Can I use the eero PoE 7 with my existing eero hardware?
The eero PoE 7 is fully compatible with existing eero hardware. However, to take full advantage of eero PoE 7’s tri-band capabilities, we recommend using eero PoE 7 together with other Wi-Fi 7 eero hardware.
What do I need to set up my eero PoE 7?
Similar to other eero products, the eero PoE 7 requires the use of the Android or iOS eero App for setup and network management.
Additionally, if using PoE, the eero PoE 7 requires PoE wired infrastructure.
See our PoE 7 Installation guide for more information on the setup process.
Can I mount the eero PoE 7 onto dropped ceilings?
The eero PoE 7 can be mounted onto suspended ceiling tile grids (otherwise known as dropped ceilings) by using a T-Bar mount. This T-Bar mount is manufactured by accessories supplier Ventev, and is available for purchase on Amazon.
Is eero PoE 7 compatible with eero subscription services?
The eero PoE 7 is compatible with eero Plus as well as eero Business (EB).
What is the warranty for eero PoE 7?
The eero PoE 7 is backed by a limited 3 year warranty, on top of eero’s extensive phone and email support. For more information about our limited warranty, please see What is eero’s warranty?
