eero Hotspot Backup allows you to set up a nearby mobile hotspot or wifi network as a backup when your wired internet goes down. Once enabled, eero Hotspot Backup will look for and connect to the available and compatible backup source you’ve set, keeping you online to focus on what matters most.
With eero Hotspot Backup and a capable hotspot, you can enjoy video streaming, video conferencing, music streaming or online gaming even during internet outages. eero Hotspot Backup detects when an outage is over and automatically switches back to your original internet connection, giving you one less thing to worry about.
eero Internet Backup is a feature of eero Plus, our premium subscription service and select subscriptions sold by ISPs and Ring. For a limited time, we are offering Internet Backup free for all eero customers who purchase through retail channels. To use this feature, check you have the latest version of the eero app by navigating to Settings > Troubleshooting > About from the eero mobile application.
- Wireless reliability - Wirelessly connect your eero network to a backup hotspot without having to physically connect anything.
- Roam around your whole home - When you move around your home, your mobile device’s backup hotspot will connect to any nearby compatible eero device extending the backup hotspot across your whole network.
- Quickly restore internet - When the internet goes down, it’s easy to temporarily switch your eero network over to your backup source, promptly broadcasting it throughout your home—so your connected devices stay online.
- Reconnect your home - With a backup connection, your connected home devices, including security devices and smart appliances, can stay online even when internet outages occur.
- Stream on - Keep enjoying video streaming, video conferencing, music streaming, or online gaming even during network outages with capable hotspots.
- Bring your own backup - Select up to eight backup wireless connections including wireless hotspots or nearby wifi networks with no need to physically connect anything.
- Only on when needed - When the outage is over, your eero network will automatically switch back to your wired internet connection.
- Reduce hotspot strain -Choose which connected devices get wifi access to prioritize what’s most critical across your network.
How do I set up a backup network?
- In your eero app, scroll down to Security & privacy and tap on the panel to the right to access the eero Plus feature menu.
- Select eero Hotspot Backup to enable the feature.
- Make sure your backup network is available (if you are using a mobile hotspot, make sure it is turned on), then tap Add a backup network
- Tap on Search networks and then tap on your backup network when it appears on the list.
- Follow the prompts to add your password and complete setup.
- You should now see your backup network on the main Hotspot Backup screen.
- You can add up to eight backup networks by simply repeating this process.
Can I set up eero Hotspot Backup during an outage?
If your eero network is running minimum eeroOS v6.13.0 and your eero app is updated to minimum v6.25.1 You can still set up a new backup connection even if your network is offline due to an internet outage.
Where can I learn how to improve network performance while using eero Hotspot Backup, or find troubleshooting and feature compatibility information?
For tips on how to improve network performance plus troubleshooting and feature compatibility information, go to our Troubleshooting eero Hotspot Backup guide.
How does custom DNS work with eero Hotspot Backup?
Once eero Hotspot Backup is enabled on your network, your gateway eero's IP address will be provided as the nameserver.
How long will eero Hotspot Backup work as a backup connection?
While eero Hotspot Backup can run for the duration of your outages (subject to any backup limits), customers should confirm with their service provider how much data usage is allowed if they plan to rely on eero Hotspot Backup for extended periods of time. eero Hotspot Backup will continue monitoring your primary internet source and automatically switch back when your primary internet source is available again.
Will eero Hotspot Backup help keep all my connected devices online? If not, how many devices can it support when enabled?
The devices already on your network will still connect to the internet with eero Hotspot Backup running, but coverage, speeds, and reliability will depend on the backup network you are using. To learn how to enable and disable network access for your connected devices while running eero Internet Backup, go to our Troubleshooting eero Hotspot Backup guide.
Am I able to take advantage of eero Hotspot Backup without an eero subscription?
eero Hotspot Backup is a feature of eero Plus, our premium subscription service, and select subscriptions sold by ISPs and Ring. For a limited time, we are offering eero Hotspot Backup free for all eero customers who purchase through retail channels.
How does eero Hotspot Backup work with my Ring Alarm Pro?
If you have enabled both 24/7 Backup Internet with your Ring AI Pro subscription, and eero Hotspot Backup with your eero Plus subscription, eero will default to using your Ring failover solution first, and eero Hotspot Backup will act as secondary failover solution if eero cannot connect to Ring 24/7 Backup Internet (e.g., because of data limitations).
Limited time offer
eero Hotspot Backup feature will be made available through the eero app for all retail eero customers, starting August 20, 2024, for a limited time only. This offer may be modified or canceled at any time.
Legal Disclaimer:
eero Hotspot Backup requires a compatible backup internet connection in range of a compatible eero device, and an eero Plus (formerly eero Secure+) subscription, or qualifying ISP or Ring subscription, all sold separately. eero does not guarantee zero disruption and brief network downtime may occur during failover. Customer is responsible for applicable data charges with backup internet connection providers and ensuring authorized use. Network speeds are dependent on the backup provider, and coverage, uptime, technology, and speeds will vary. Will require backup power if the power goes out. Certain eero or Amazon features may be incompatible with eero Hotspot Backup. Visit eero.com/eero-plus for more details. Use of eero and eero Hotspot Backup are subject to eero’s Terms of Service and Subscription Terms of Service, found at eero.com/legal
