Introducing eero PoE Gateway
eero PoE Gateway
eero PoE Gateway is a multi-gigabit wired gateway capable of powering up to 8 eero PoE 6 access points or up to 6 eero Outdoor 7 access points to provide wifi coverage throughout your home or business. eero PoE Gateway also powers other PoE devices, featuring two 10 GbE ports and eight PoE-capable 2.5 GbE ports.
With the included 140W power supply, eero PoE Gateway is a wired gateway that supplies 100W of pooled power for PoE /PoE-enabled devices up to 802.3bt Type 2 Class 4, including multiple eero PoE 6, eero PoE 7, and eero Outdoor 7 access points.
You can learn more about eero PoE Gateway set up with the eero PoE gateway installation guide.
eero PoE Gateway Technical Specifications
Wifi coverage N/A
Type Wired Gateway
Wired network speed Up to 9.4 Gbps
Wifi standard N/A
Number of wifi radios N/A
Ethernet ports
2x auto-sensing 10 GbE port, RJ45
8x auto-sensing 2.5 GbE PoE-PSE port, RJ-45
Placement Shelf / tabletop
