Our support ticketing system will be undergoing maintenance between 3/22-3/24/25 as we perform essential maintenance to improve our services. While our phone support will remain operational during this time, customers may experience longer than usual hold times.
Can I connect my eeros with Ethernet?
Yes. eeros can be connected together via Ethernet backhaul or they can connect wirelessly. If your home is already wired with Ethernet, you may want to take advantage of these connections to increase the range of your eeros and reduce the risk of wireless interference.
When connecting your eeros via Ethernet, you can either connect all your eeros to your gateway eero (via an Ethernet Switch with the gateway connected to the modem/ONT), or you connect each eero to one another (daisy chain). Also see Examples of common network topologies.
What about eero Beacons?
eero Beacons do not have any Ethernet ports, so they cannot be connected to your network over Ethernet. They can, however, be part of a mixed network of wired and wireless eeros.
