How do I delete my network?
Deleting your eero wifi network will remove your eeros and reset your settings. This allows you to set up your eeros in another home or on a network.
Steps to delete your eero network:
  • Tap Settings.
  • Tap Network Settings.
  • Scroll to the bottom of the app page.
  • Tap 'Delete Network'.
    • A confirmation page will display.
  • Tap the 'Delete Network' button
