How can I find the connection strength and status of my eeros?
Keeping your eeros connected is essential for keeping your mesh network running smoothly. After initial placement of your eeros, you shouldn’t ever need to move them again. However, if you notice a drop-off or feel you are not getting the best performance, you can use the "Connection details" section under the individual eeros to improve wireless connectivity to your gateway eero(the eero connected directly to your modem).
To check your eero’s connection quality, take the following steps:
  • Open the eero app
  • Tap Online at the top of the screen
  • The signal strength of each eero will be displayed to the right of the name of each eero
  • Note: If you eero is wired it will display a <-> icon.
Note: if you are running a wired network, meaning all or any of your eeros are connected via Ethernet, the connection details section will only show “Wired” with a wired icon for that eero. Adjusting placement of these eeros may improve the connection quality to your external devices, however, such repositioning will not improve any network issues you may have. For these cases, please contact support.
The "Connection details" section will provide greater insight into the strength of the wireless connection from an eero placed in your home to the gateway eero. For more on what these strengths mean for your network, see the chart below:
An image depicting what the various signal strength levels indicate. 5 bars is an excellent, stable connection. 4 bars is a strong, stable connection, though there may be some interference. 3 bars is a good, stable connection, but has more significant interference. 2 bars is a stable connection, but likely needs to be moved to an area with less interference, or closer to the other eero(s). 1 bar is a weak connection and needs to be corrected.
If your signal strength for an eero is one bar, you will see an option appear in yellow that states Fix poor connection, tap to follow the steps provided.
If you are continuing to see a poor connection for a particular eero, you may want to contact our support if changing the placement of your eero doesn’t help. Feel free to give us a call at 1-877-659-2347 or email us.
