Using your Amazon Login with eero
Using your Amazon.com account to sign into eero not only streamlines your login experience but makes it easier to centralize control of your connected home with features like Amazon Frustration-Free Setup and Alexa Smart Home Hub. By using your Amazon login to access the eero app, you instantly receive Amazon account security features like multi-factor authentication and security alerts.
New customers will have the option to use their Amazon credentials from initial account creation. Existing accounts will be able to switch to Amazon login by following the flow under Account Settings in the mobile app. Once you switch, your previous eero login credentials will no longer be valid.
If you or your family have multiple Amazon accounts, we recommend choosing the account you use to control Alexa and your smart home devices.
